Zum Hauptinhalt wechseln
Withings Smart Body Analyzer Motherboard Replacement
Was du brauchst
  1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: Schritt 1, Bild 1 von 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Motherboard Replacement: Schritt 2, Bild 1 von 3 Withings Smart Body Analyzer Motherboard Replacement: Schritt 2, Bild 2 von 3 Withings Smart Body Analyzer Motherboard Replacement: Schritt 2, Bild 3 von 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Motherboard Replacement: Schritt 3, Bild 1 von 2 Withings Smart Body Analyzer Motherboard Replacement: Schritt 3, Bild 2 von 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
  5. Withings Smart Body Analyzer Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
  6. Withings Smart Body Analyzer Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Once the two screws and the ribbon cable are detached, remove the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - Antwort
where do you get the motherboard?
cost?
donald taylor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 37
Insgesamt: 4,900
