Zum Hauptinhalt wechseln
Withings Smart Body Analyzer Pressure Sensor Replacement
Was du brauchst
  1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: Schritt 1, Bild 1 von 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 2, Bild 1 von 3 Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 2, Bild 2 von 3 Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 2, Bild 3 von 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 3, Bild 1 von 2 Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 3, Bild 2 von 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: Schritt 4, Bild 1 von 1
    • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
    • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
  5. Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 5, Bild 1 von 2 Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
  6. Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 6, Bild 1 von 2 Withings Smart Body Analyzer Pressure Sensor Replacement: Schritt 6, Bild 2 von 2
    • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Where do I get those replacements?
karina - Antwort
where can I buy pressure sensors?
Andrey Kolesov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 3,872
