Einleitung
If your blender does not operate, try opening it as per this guide and checking the wires on the control board. If that yields no results, consider replacing the board if possible.
  1. Flip the base of the blender upside-down. Remove the four 1/2" long screws in the corners of the base using a Phillips #2 screwdriver.
    • Flip the base of the blender upside-down.
    • Remove the four 1/2" long screws in the corners of the base using a Phillips #2 screwdriver.
  2. Using the metal spudger,  pry off one half of each rubber foot. Note that one side of the foot is glued down; pry off the other side.
    • Using the metal spudger, pry off one half of each rubber foot.
    • Note that one side of the foot is glued down; pry off the other side.
  3. Using the same screwdriver, remove the next four 1/2" long screws in the holes under the feet.
    • Using the same screwdriver, remove the next four 1/2" long screws in the holes under the feet.
    • Pull the base off of the blender.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Pull off the plastic housing. Pull off the plastic housing.
    • Pull off the plastic housing.
  6. Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place. Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place.
    • Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place.
  7. Using pliers, pull off all the connectors on the top. Using pliers, pull off all the connectors on the top.
    • Using pliers, pull off all the connectors on the top.
  8. Pull or pry off the last connector block, then remove the control board.
    • Pull or pry off the last connector block, then remove the control board.
Abschluss
Cole Gillespie
464 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S25-G16, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 55
