Einleitung
If your blender is leaking or making strange noises, consider replacing the O-ring.
Was du brauchst
Flip over the pitcher to expose the base of the blade assembly.
Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
Fast fertig!
Abschluss
