Einleitung
If your power cord is broken and your blender will not turn on, follow these steps to replace it.
Was du brauchst
With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
Pull the plastic cover off.
Pull the cut power cord through the base.
Then thread the replacement cord back through and re-attach the plastic cover.
Strip about an inch of insulation off of the snipped power cord and your replacement cord.
Twist each strand of wires together to keep them neat.
Twist together the wires from the replacement cord to the wires still attached to the blender.
Solder the connection if possible.
To reassemble your device, follow steps 1-5 in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
