Einleitung
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
Was du brauchst
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
Remove the final 8mm screw in the slide lever.
The lever can now pull away from the entire unit.
Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
Remove the outer shell from the device.
Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
Use pliers to pull apart the three electrical connectors pictured in the graphic.
