Zum Hauptinhalt wechseln
Wolf Gourmet WGTR102S Electrical Connection Replacement
Was du brauchst
  1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: Schritt 1, Bild 1 von 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 3, Bild 1 von 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 6, Bild 1 von 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 7, Bild 1 von 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 8, Bild 1 von 2 Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: Schritt 9, Bild 1 von 1
    • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
  10. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 10, Bild 1 von 1
    • Use pliers to pull apart the three electrical connectors pictured in the graphic.
  11. Wolf Gourmet WGTR102S Electrical Connection Replacement: Schritt 11, Bild 1 von 1
    • Replace the electrical connectors.
Abschluss
Ryan Funchess
697 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S22-G5, Maness Spring 2018 Mitglied von Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 722
