Einleitung
If the toaster is not responding to the heat dial, try replacing the circuit board with this guide.
Was du brauchst
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
Remove the final 8mm screw in the slide lever.
The lever can now pull away from the entire unit.
Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
Remove the outer shell from the device.
Remove the two 4mm screws found on each side of the circuit board using a Tri-point Y1 screwdriver.
