Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If you need to access the inside of your toaster to fix problems, start by removing the outer shell with this guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Remove the crumb collector located on the bottom of the toaster.
    • Remove the crumb collector located on the bottom of the toaster.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Remove the three 8mm screws using the Tri-point Y1 screwdriver.
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  6. Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  7. Remove the final 8mm screw in the slide lever.
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  8. Remove toaster's outer shell by lifting straight up.
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  9. Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors. Remove the outer shell from the device.
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Ryan Funchess
697 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S22-G5, Maness Spring 2018 Mitglied von Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 127
