Einleitung
If your toast rack does not slide up all the way, or your toast pops up too fast, try replacing the slide assist plunger with this guide.
Was du brauchst
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
Remove the final 8mm screw in the slide lever.
The lever can now pull away from the entire unit.
Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
Remove the outer shell from the device.
Remove the top panel by bending the tabs on each side straight up.
Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
Has anyone found a source for the WOLF toaster plunger?
Any pointers on where to find Wolf replacement parts ?
