Zum Hauptinhalt wechseln
Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
Was du brauchst
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: Schritt 1, Bild 1 von 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 3, Bild 1 von 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 6, Bild 1 von 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 7, Bild 1 von 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 8, Bild 1 von 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: Schritt 9, Bild 1 von 1
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 11, Bild 1 von 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: Schritt 11, Bild 2 von 2
    • Remove the plunger from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Funchess
697 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S22-G5, Maness Spring 2018 Mitglied von Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Mitglieder
4 Kommentare
Where does one get a new plunger for the replacement?
hsernaker - Antwort
yes, where does one get a new pludger?
hiyar124 - Antwort
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - Antwort
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,063
