Einleitung
The Wolfgang Puck Pie Maker was released in 2012 by WP Appliances. It has since been discontinued. After frequent use, many users of the device have claimed that there is uneven heating caused by shifts in the heating coil. All the wiring is internally located and requires a #2 Phillips head screwdriver to access. If the device has been used recently, the inside may still be very hot.
Was du brauchst
Open up the pie maker using the two main handles so it's open as shown in the picture.
Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
Remove the inside handle cover.
Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
Remove the top cover by pulling it off of the device.
To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
The temperature sensor can be accessed by lifting the bottom side of the device as shown.
