Zum Hauptinhalt wechseln
Wood Stool Leg Glide Replacement
Was du brauchst
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: Schritt 1, Bild 1 von 1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: Schritt 2, Bild 1 von 1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: Schritt 3, Bild 1 von 1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: Schritt 4, Bild 1 von 1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: Schritt 5, Bild 1 von 1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: Schritt 6, Bild 1 von 1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: Schritt 7, Bild 1 von 2 Wood Stool Leg Glide Replacement: Schritt 7, Bild 2 von 2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Abschluss
Molly Ristig
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 387
