Zum Hauptinhalt wechseln
Wooden Fence Picket Replacement
Was du brauchst
  1. Wooden Fence Picket Replacement, Picket: Schritt 1, Bild 1 von 3 Wooden Fence Picket Replacement, Picket: Schritt 1, Bild 2 von 3 Wooden Fence Picket Replacement, Picket: Schritt 1, Bild 3 von 3
    • IMPORTANT: This step will need to be completed before continuing. You will need to use these measurements to purchase a replacement picket needed later in the guide.
    • Use the tape measure to measure the height, width, and depth of the picket.
    • Use these measurements to purchase a replacement picket. Home Depot and Lowe's are good places to purchase a picket. If you are unfamiliar with what you are doing, ask any worker there for some help and they will help you get your replacement.
  2. Wooden Fence Picket Replacement: Schritt 2, Bild 1 von 3 Wooden Fence Picket Replacement: Schritt 2, Bild 2 von 3 Wooden Fence Picket Replacement: Schritt 2, Bild 3 von 3
    • Place the tip of the pry bar under the picket, in line with the nails.
    • Use a hammer to push the pry bar under the picket.
    • Use soft taps with the hammer when hitting the pry bar. Using too much force may reduce accuracy and lead to injury.
    • Pull the pry bar away from the fence to remove the picket.
  3. Wooden Fence Picket Replacement: Schritt 3, Bild 1 von 3 Wooden Fence Picket Replacement: Schritt 3, Bild 2 von 3 Wooden Fence Picket Replacement: Schritt 3, Bild 3 von 3
    • Only complete this step if there are still nails in the wood after you have removed the picket. If all nails are removed, continue to Step 4.
    • Slide the claw of the hammer underneath the nail.
    • The claw is the forked area of the hammer. This is commonly used to aid in the removal of nails.
    • While holding the handle, pull on the hammer to remove the nail.
  4. Wooden Fence Picket Replacement: Schritt 4, Bild 1 von 3 Wooden Fence Picket Replacement: Schritt 4, Bild 2 von 3 Wooden Fence Picket Replacement: Schritt 4, Bild 3 von 3
    • Before installing the new picket, clear the area of any debris.
    • Obstructions may cause the picket to be crooked when installing, or make a gap too large for the nails to work properly.
    • Use the tape measure to measure the gaps between the left and right side of the picket.
    • Doing this allows the replacement picket to be centered directly between the other pickets.
  5. Wooden Fence Picket Replacement: Schritt 5, Bild 1 von 3 Wooden Fence Picket Replacement: Schritt 5, Bild 2 von 3 Wooden Fence Picket Replacement: Schritt 5, Bild 3 von 3
    • Caution: This step involves hitting nails with a hammer in close proximity to your fingers. Work gloves are recommended if you are unfamiliar with using a hammer.
    • Hold a wood nail approximately 1 inch from the side of the picket.
    • You may place the first nail 1 inch away from either the left or right side of the picket. Each section uses 2 nails so it does not matter which side you choose to work on first.
    • Lightly tap on the wood nail with the hammer to begin pushing the nail into the picket. Continue until the nail is fully in the picket.
    • Repeat until there are 2 nails inserted in the picket at every cross section.
Abschluss
This guide only demonstrates how to replace a picket on a wooden fence. For questions regarding staining your fence and finding the right stain, I recommend talking with a worker at a hardware store near you. They can help you find the right product and make sure your new picket matches the rest of your fence.
David Snowden
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 2,415
