Zum Hauptinhalt wechseln
World Dryer Airforce J4-973A3 Motor Replacement
Was du brauchst
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: Schritt 1, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: Schritt 1, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: Schritt 1, Bild 3 von 3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 2, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 2, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 3, Bild 1 von 2 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
  5. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 5, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 5, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 5, Bild 3 von 3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
  6. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 6, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 6, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 6, Bild 3 von 3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  7. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 7, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 7, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 7, Bild 3 von 3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
  8. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 8, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 8, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 8, Bild 3 von 3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
  9. World Dryer Airforce J4-973A3 Motor Replacement: Schritt 9, Bild 1 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 9, Bild 2 von 3 World Dryer Airforce J4-973A3 Motor Replacement: Schritt 9, Bild 3 von 3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
Abschluss
Eli Forbes
172 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G6, Hope Fall 2018 Mitglied von Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 302
