Zum Hauptinhalt wechseln
World Dryer Airforce J4-973A3 Sensor Board Replacement
Was du brauchst
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: Schritt 1, Bild 1 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: Schritt 1, Bild 2 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: Schritt 1, Bild 3 von 3
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 2, Bild 1 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 2, Bild 2 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 2, Bild 3 von 3
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 3, Bild 1 von 2 World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 3, Bild 2 von 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 4, Bild 1 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 4, Bild 2 von 3 World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 4, Bild 3 von 3
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the sensor board from your device.
Abschluss
Luke Clancy
123 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G6, Hope Fall 2018 Mitglied von Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 661
