Zum Hauptinhalt wechseln
World Dryer Airforce J4-973A3 Server Board Replacement
Was du brauchst
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: Schritt 1, Bild 1 von 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: Schritt 1, Bild 2 von 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: Schritt 1, Bild 3 von 3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 2, Bild 1 von 2 World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 2, Bild 2 von 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 3, Bild 1 von 3 World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 3, Bild 2 von 3 World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 3, Bild 3 von 3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 4, Bild 1 von 3 World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 4, Bild 2 von 3 World Dryer Airforce J4-973A3 Server Board Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Abschluss
Blane Hirsh
260 Reputation
2 Anleitungen geschrieben
Washington State, Team S1-G6, Hope Fall 2018 Mitglied von Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 271
