Zum Hauptinhalt wechseln
WowWee CHiP Robot Dog Smart Watch Battery Replacement
Was du brauchst
  1. WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: Schritt 1, Bild 1 von 2 WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: Schritt 1, Bild 2 von 2
    • Place the Smart Watch on its back or side so that the full watch band is visible.
  2. WowWee CHiP Robot Dog Smart Watch Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the wrist strap by gently pulling the band off of the plastic pegs on the back of the watch.
  3. WowWee CHiP Robot Dog Smart Watch Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the four screws in the back of the watch using a Phillips #0 screwdriver.
  4. WowWee CHiP Robot Dog Smart Watch Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently pull off the back side of the watch component.
  5. WowWee CHiP Robot Dog Smart Watch Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull the battery and motherboard component out.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
What batteries does the smart band use?
Yourmajesty100 - Antwort
Can be replaced by one of these and some soldering.
https://www.adafruit.com/product/1317
Alto -
This doesn’t detail sourcing the replacement or un-soldering then soldering the battery.
This is just “WowWee CHiP Robot Dog Smart Watch Battery Inspection” Not Replacement.
Alto - Antwort
But the discussion is under battery replacement
Daniel peters -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 3,439
