Zum Hauptinhalt wechseln
WowWee CHiP Robot Dog Wheel Replacement
Was du brauchst
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: Schritt 2, Bild 1 von 2 WowWee CHiP Robot Dog Wheel Replacement: Schritt 2, Bild 2 von 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: Schritt 3, Bild 1 von 2 WowWee CHiP Robot Dog Wheel Replacement: Schritt 3, Bild 2 von 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: Schritt 4, Bild 1 von 3 WowWee CHiP Robot Dog Wheel Replacement: Schritt 4, Bild 2 von 3 WowWee CHiP Robot Dog Wheel Replacement: Schritt 4, Bild 3 von 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: Schritt 5, Bild 1 von 1
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: Schritt 6, Bild 1 von 1
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: Schritt 7, Bild 1 von 1
    • Pull and remove wheel.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Antwort
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 3,934
