Was du brauchst
There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
