Zum Hauptinhalt wechseln
WowWee MiP Robot Power Switch Replacement
Was du brauchst
  1. WowWee MiP Robot Power Switch Replacement, Battery: Schritt 1, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: Schritt 2, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement: Schritt 2, Bild 2 von 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: Schritt 3, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement, Wheel: Schritt 3, Bild 2 von 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot Power Switch Replacement: Schritt 4, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement: Schritt 4, Bild 2 von 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: Schritt 6, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: Schritt 6, Bild 2 von 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: Schritt 7, Bild 1 von 3 WowWee MiP Robot Power Switch Replacement: Schritt 7, Bild 2 von 3 WowWee MiP Robot Power Switch Replacement: Schritt 7, Bild 3 von 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: Schritt 9, Bild 1 von 2 WowWee MiP Robot Power Switch Replacement, Power Switch: Schritt 9, Bild 2 von 2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: Schritt 10, Bild 1 von 1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 3-4, Wollert Spring 2016 Mitglied von USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
where can i buy the power switch of MiP
Reinejoe Cacho - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 662
