Einleitung
The power switch turns the MiP on or off. If it's malfunctioning the robot will not work.
Was du brauchst
Carefully pull the battery pack from the robot.
Remove the batteries from the battery pack.
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using precision tweezers, disconnect the following three bundles of wires:
Connecting the battery pack to the motherboard.
Connecting the power switch to the motherboard.
Connecting the speaker to the motherboard.
Remove the power switch assembly from the body by gently pulling straight out on the wires.
2 weitere Personen haben diese Anleitung absolviert.
