Einleitung
This guide shows you which screws and which pieces to remove in order to access the wheel housing.
Was du brauchst
Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
Remove 1.2 mm Phillips screw from the white plastic piece in the center of the wheel and then remove the wheel entirely.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
