Zum Hauptinhalt wechseln
Wyze Cam V2 Motherboard Replacement
Was du brauchst
  1. Wyze Cam V2 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Motherboard Replacement: Schritt 3, Bild 1 von 2 Wyze Cam V2 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Motherboard Replacement: Schritt 4, Bild 1 von 2 Wyze Cam V2 Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
  5. Wyze Cam V2 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
Abschluss
Oluajo
243 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 508
