Zum Hauptinhalt wechseln
Wyze Cam V2 Speaker Replacement
Was du brauchst
  1. Wyze Cam V2 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Wyze Cam V2 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
    Frag FixBot
  3. Wyze Cam V2 Speaker Replacement: Schritt 3, Bild 1 von 2 Wyze Cam V2 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
    Frag FixBot
  4. Wyze Cam V2 Speaker Replacement: Schritt 4, Bild 1 von 2 Wyze Cam V2 Speaker Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    Frag FixBot
  5. Wyze Cam V2 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Wyze Cam V2 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Remove the two 6 mm screws from the back cover with a Phillips #0 screwdriver.
    • Carefully lift off the speaker plate.
    Frag FixBot
  6. Wyze Cam V2 Speaker Replacement: Schritt 6, Bild 1 von 2 Wyze Cam V2 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the speaker using the spudger.
    Frag FixBot
Abschluss
1 Kommentar zur Anleitung
so I have a V3 that I got from what not and it came in broken because the speaker is making a crackling sound. Do you think The speaker will also work on a V3?
Anna - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 348
