Zum Hauptinhalt wechseln
Wyze WVCR200s Battery Replacement
Was du brauchst
  1. Wyze WVCR200s Battery Replacement, Rotating Brush: Schritt 1, Bild 1 von 1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Battery Replacement: Schritt 2, Bild 1 von 2 Wyze WVCR200s Battery Replacement: Schritt 2, Bild 2 von 2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Battery Replacement: Schritt 3, Bild 1 von 3 Wyze WVCR200s Battery Replacement: Schritt 3, Bild 2 von 3 Wyze WVCR200s Battery Replacement: Schritt 3, Bild 3 von 3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
  4. Wyze WVCR200s Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
  5. Wyze WVCR200s Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery cover up and out of the vacuum.
  6. Wyze WVCR200s Battery Replacement: Schritt 6, Bild 1 von 2 Wyze WVCR200s Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery out from underneath the cover.
    • Be careful not to pull or yank the battery out, it is connected by wires to the vacuum port.
    • Carefully disconnect the battery from the vacuum port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brandon Amado
411 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 30
Letzte 30 Tage: 146
Insgesamt: 1,392
