Zum Hauptinhalt wechseln
Wyze WVCR200s Bumper Replacement
Was du brauchst
  1. Wyze WVCR200s Bumper Replacement, Side Brush: Schritt 1, Bild 1 von 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Bumper Replacement: Schritt 2, Bild 1 von 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  3. Wyze WVCR200s Bumper Replacement, Bumper: Schritt 3, Bild 1 von 1
    • Flip the vacuum over.
  4. Wyze WVCR200s Bumper Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  5. Wyze WVCR200s Bumper Replacement: Schritt 5, Bild 1 von 3 Wyze WVCR200s Bumper Replacement: Schritt 5, Bild 2 von 3 Wyze WVCR200s Bumper Replacement: Schritt 5, Bild 3 von 3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
Abschluss
Brandon Amado
411 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 99
