Einleitung
Follow this guide to replace the rotating brush from your Wyze WVCR200s robot vacuum. The rotating brush is a part of the vacuum that will need to be taken out to be cleaned regularly.
Pinch the blue tabs below the rotating brush towards each other.
Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
Fast fertig!
Abschluss
