Zum Hauptinhalt wechseln
Wyze WVCR200s Side Brush Replacement
  1. Wyze WVCR200s Side Brush Replacement, Side Brush: Schritt 1, Bild 1 von 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Side Brush Replacement: Schritt 2, Bild 1 von 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
Abschluss
Brendan
181 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 243
