Einleitung
This guide demonstrates how to replace the side brush on your Wyze WVCR200s robot vacuum. The side brush is a commonly replaced part of the vacuum. The manufacturers of the product should provide an extra side brush in the packaging.
Flip the vacuum upside down so the underside of the device is facing up.
On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
