Zum Hauptinhalt wechseln
Wyze WVCR200s Wheels Replacement
Was du brauchst
  1. Wyze WVCR200s Wheels Replacement, Rotating Brush: Schritt 1, Bild 1 von 1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Wheels Replacement: Schritt 2, Bild 1 von 2 Wyze WVCR200s Wheels Replacement: Schritt 2, Bild 2 von 2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Wheels Replacement: Schritt 3, Bild 1 von 3 Wyze WVCR200s Wheels Replacement: Schritt 3, Bild 2 von 3 Wyze WVCR200s Wheels Replacement: Schritt 3, Bild 3 von 3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
  4. Wyze WVCR200s Wheels Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
  5. Wyze WVCR200s Wheels Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery cover up and out of the vacuum.
  6. Wyze WVCR200s Wheels Replacement: Schritt 6, Bild 1 von 2 Wyze WVCR200s Wheels Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery out from underneath the cover.
    • Be careful not to pull or yank the battery out, it is connected by wires to the vacuum port.
    • Carefully disconnect the battery from the vacuum port.
  7. Wyze WVCR200s Wheels Replacement, Side Brush: Schritt 7, Bild 1 von 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  8. Wyze WVCR200s Wheels Replacement: Schritt 8, Bild 1 von 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  9. Wyze WVCR200s Wheels Replacement, Bumper: Schritt 9, Bild 1 von 1
    • Flip the vacuum over.
  10. Wyze WVCR200s Wheels Replacement: Schritt 10, Bild 1 von 1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  11. Wyze WVCR200s Wheels Replacement: Schritt 11, Bild 1 von 3 Wyze WVCR200s Wheels Replacement: Schritt 11, Bild 2 von 3 Wyze WVCR200s Wheels Replacement: Schritt 11, Bild 3 von 3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
  12. Wyze WVCR200s Wheels Replacement, Wheels: Schritt 12, Bild 1 von 2 Wyze WVCR200s Wheels Replacement, Wheels: Schritt 12, Bild 2 von 2
    • Use a spudger to pry the cover off that surrounds the vacuum mechanism.
    • Remove the two screws securing the access cover.
    • Remove the cover.
  13. Wyze WVCR200s Wheels Replacement: Schritt 13, Bild 1 von 2 Wyze WVCR200s Wheels Replacement: Schritt 13, Bild 2 von 2
    • Use a screwdriver to remove the eight screws surrounding the vacuum mechanism cover.
    • Use a screwdriver to remove the four screws holding the mechanism itself.
    • Lift the vacuum mechanism from the device.
    • It is connected to the vacuum by a cable so don't pull it out quickly or yank it out.
    • Disconnect the cable from the vacuum.
  14. Wyze WVCR200s Wheels Replacement: Schritt 14, Bild 1 von 3 Wyze WVCR200s Wheels Replacement: Schritt 14, Bild 2 von 3 Wyze WVCR200s Wheels Replacement: Schritt 14, Bild 3 von 3
    • Use a screwdriver to remove the ten screws on the back side of the vacuum that hold the outer shell in place.
    • Use a spudger or opening tool to pry along the edges of the vacuum and separate the two parts.
  15. Wyze WVCR200s Wheels Replacement: Schritt 15, Bild 1 von 3 Wyze WVCR200s Wheels Replacement: Schritt 15, Bild 2 von 3 Wyze WVCR200s Wheels Replacement: Schritt 15, Bild 3 von 3
    • The wheels are located on each side of the vacuum.
    • Use a screwdriver to remove three screws from each wheel holding them in place.
    • Remove the wheels.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 89
Insgesamt: 1,029
