Einleitung
This guide will involve the quick removal of one of the wheels to either be replaced or to have the car axis cleaned.
Was du brauchst
Remove the wheel. Begin by grabbing your metal spudger or a guitar pick to pop off the plastic cap in the middle of the wheel.
Use the #2 Phillips screwdriver to remove the 4mm Phillips #2 screw inside the wheel.
From here you should be able to easily pull off the wheel from the car and you're finished!
Eine weitere Person hat diese Anleitung absolviert.
