Einleitung
If the power button on your device is not working, consider using this guide to remove and replace it for your device.
Was du brauchst
Remove the two screws using a Phillips #0 screwdriver.
Pry the back cover carefully and continue going around the device.
Remove three screws that are attached to the motherboard using the Phillips #0 screwdriver.
Carefully lift the motherboard to free up the faulty power button and take it out.
Replace the power button.
For easy installation, have the tablet placed vertically while inserting the power button.
