Einleitung
Use this guide to replace a malfunctioning volume button in your device.
Was du brauchst
Remove the two screws using a Phillips #0 screwdriver.
Pry the back cover carefully and continue going around the device.
Remove three screws that are attached to the motherboard using the Phillips #0 screwdriver.
Carefully lift the motherboard to free up the faulty volume button and take it out.
Abschluss
