Zum Hauptinhalt wechseln
X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement
Was du brauchst
  1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 2, Bild 1 von 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Underbody: Schritt 3, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 5, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 5, Bild 2 von 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 7, Bild 1 von 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 8, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 9, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 9, Bild 2 von 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 10, Bild 1 von 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 11, Bild 1 von 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: Schritt 12, Bild 1 von 3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: Schritt 12, Bild 2 von 3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: Schritt 12, Bild 3 von 3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Front Steering Motor: Schritt 13, Bild 1 von 1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing
  14. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 14, Bild 1 von 1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 15, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 15, Bild 2 von 2
    • Remove the remaining three 1.6 mm Phillips #000 screws from the black motor casing
    • The second image shows the screws removed from the casing.
  16. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: Schritt 16, Bild 1 von 1
    • Pull out the front motor, making sure to keep the gears intact
Abschluss
Cal Poly, Team 24-3, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Mitglieder
9 Anleitungen geschrieben
1 Kommentar zur Anleitung
How many volts is the battery?
DC2 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 828
