Zum Hauptinhalt wechseln
X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement
Was du brauchst
    1. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
      • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
      • Unclip the two clips to remove the battery cover.
      Frag FixBot
      Kommentar hinzufügen
    2. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 2, Bild 1 von 1
      • Unplug the battery by pushing on the clip.
      Frag FixBot
    1. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Underbody: Schritt 3, Bild 1 von 1
      • Unscrew the two 2.5mm Phillips #00 screws from each side
      Frag FixBot
    2. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 4, Bild 1 von 1
      • Remove the side skirt covers on each side of the car.
      Frag FixBot
    3. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 5, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 5, Bild 2 von 2
      • Lift up and remove the two side skirts.
      Frag FixBot
    4. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 6, Bild 1 von 1
      • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
      Frag FixBot
    5. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 7, Bild 1 von 1
      • Lift the front part of the underbody and pull it out from the main underbody.
      Frag FixBot
    6. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 8, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 8, Bild 2 von 2
      • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
      • The second image shows a closer view of the rear three screws
      Frag FixBot
    7. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 9, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 9, Bild 2 von 2
      • Lift the main underbody from the shell of the car.
      • Lift up the body to expose the wiring and hardware underneath.
      Frag FixBot
    8. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 10, Bild 1 von 1
      • Remove the reflective sticker from the top of the body.
      Frag FixBot
    9. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 11, Bild 1 von 1
      • Unplug the wire connector.
      Frag FixBot
    1. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
      • Desolder all wires connected to the motherboard.
      • In this step, you will have to take great care in keeping track of the wires
      • Our suggestion is to attach tape to each wire, and letter the tape. Letter each tape according to the respective lettering found on the motherboard.
      Frag FixBot
    2. X-street Lamborghini Murcielago LP670-4 SV Motherboard Replacement: Schritt 13, Bild 1 von 1
      • Unscrew the two 1.6mm Phillips #000 screws connecting the motherboard to the under body of the car.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 24-3, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Mitglieder
29 Anleitungen geschrieben
3 Kommentare zur Anleitung
Hello I need to buy new circuit, can u guide me to any webstore? Thanx
mmekawtar - Antwort Teilen
Where can I by a replacement circuit board? PLease.
Joe Welsh - Antwort Teilen
I buy a car but there is no charging cable
I need charging cable
abid khan - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 45
Insgesamt: 1,263
