Zum Hauptinhalt wechseln
X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement
Was du brauchst
  1. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 2, Bild 1 von 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Underbody: Schritt 3, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 5, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 5, Bild 2 von 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 7, Bild 1 von 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 8, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 9, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 9, Bild 2 von 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 10, Bild 1 von 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 11, Bild 1 von 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement, Rear Motor: Schritt 12, Bild 1 von 1
    • Unscrew the two 2.5mm Phillips #00 screws on the white covering of the rear motor casing.
    • There is a plastic casing over the rear motor. Simply remove this plastic covering and proceed.
  13. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 13, Bild 1 von 2 X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 13, Bild 2 von 2
    • Remove all ten 1.6mm Phillips #000 screws from the rear motor casing
    • The first image shows five screws on the side with the circuitry
    • The second image shows five screws on the opposite side of the casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Rear Motor Replacement: Schritt 14, Bild 1 von 1
    • Use a soldering gun to remove the attached wires
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 24-3, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 Mitglieder
9 Anleitungen geschrieben
1 Kommentar zur Anleitung
what size is the motor
mattsson97 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 721
