Einleitung
This guide will walk you through the steps to disassemble the XMAX V3 Pro, providing a detailed look at its internal components.
Was du brauchst
Apply heat from a hair dryer to help soften the glue
Use a spudger to pry off bottom cover
Use your thumb to apple pressure in the direction of the arrow
The entire assembly should slide out of the metal case
The rubber gasket that can be seen better in step 11 stops air from entering the heating assembly from the motherboard area and only allows it to be drawn in the the side perforations.
Air enters though the area within the red square and then goes though the hole within the red circle
Use a spudger to completely remove the gold battery contact from case
Remove rubber gasket, simply slide it down the heater assembly
Desolder positive battery terminal and both heater wires
Desolder both temperature probe wires
Remove both P000 screws
Pull out positive battery terminal assembly
Use a nail or spudger to remove the heater core from the outside housing
4 weitere Nutzer:innen haben diese Anleitung absolviert.
