Zum Hauptinhalt wechseln
XPS M2010 MXP061 Hard Drive Replacement
Was du brauchst
  1. XPS M2010 MXP061 Hard Drive Replacement, Removing the Cosmetic Cover: Schritt 1, Bild 1 von 1
    • After turning off the computer and opening the display, remove the keyboard from the computer.
    • With a flat-head screwdriver, press in the cover-release slot (#3) on the side of the computer.
    • While holding the screwdriver in (so that the button inside the slot is still being held), lift up the cosmetic cover (#2) by the cosmetic-cover notch (#1).
  2. XPS M2010 MXP061 Hard Drive Replacement, Removing the Top Cover: Screws: Schritt 2, Bild 1 von 1
    • Unscrew the six M2.5 x 5-mm screws on the left side (#1) of the top cover, then unscrew the seven M2.5 x 5-mm screws on the right side (#2) of the top cover.
  3. XPS M2010 MXP061 Hard Drive Replacement, Removing the Top Cover: Cables: Schritt 3, Bild 1 von 1
    • Slightly lift up the top cover, but do not fully remove it. Two cables are connected to the top cover, and they could be damaged if the top cover is improperly removed.
    • While holding the top cover up, unplug the two cable connectors by pulling up on the pull loop or connector.
  4. XPS M2010 MXP061 Hard Drive Replacement, Free Hard Drive: Schritt 4, Bild 1 von 1
    • Loosen the four captive screws on each corner of the hard drive bracket.
  5. XPS M2010 MXP061 Hard Drive Replacement, Remove Hard Drive From Sytem: Schritt 5, Bild 1 von 1
    • Lift the hard drive only a few inches, and disconnect the data cable from the system board by pulling up on the black tab.
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging or on a surface that does not conduct electricity, like wood.
  6. XPS M2010 MXP061 Hard Drive Replacement, Remove Hard Drive From Bracket: Schritt 6, Bild 1 von 1
    • Remove the four M3 x 3-mm screws that attach the hard drive to the hard drive bracket.
  7. XPS M2010 MXP061 Hard Drive Replacement, Disconnect Hard Drive From Cable: Schritt 7, Bild 1 von 1
    • Pull the strap on the hard drive cable to remove the data cable from the hard drive. Reserve this cable for use with the new hard drive.
  8. XPS M2010 MXP061 Hard Drive Replacement, Attach New Hard Drive to Bracket: Schritt 8, Bild 1 von 1
    • Attach the new hard drive to the brackets using four M3 x 3-mm screws.
  9. XPS M2010 MXP061 Hard Drive Replacement, Connect To Data Cable: Schritt 9, Bild 1 von 1
    • Connect the data cable to the new hard drive.
  10. XPS M2010 MXP061 Hard Drive Replacement, Data Cable to System Board: Schritt 10, Bild 1 von 1
    • Connect the hard drive cable to the appropriate connector on the system board
  11. XPS M2010 MXP061 Hard Drive Replacement, Secure hard drive to system: Schritt 11, Bild 1 von 1
    • Align the captive screws in each corner of the hard drive with the holes in the frame and tighten the screws.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
Ein Kommentar
Hey Johnathan, can you include some information on how to remove the top cover and the cosmetic cover so the hard drive can be accessed?
William Daniels - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 1,239
