Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will help the owner of a Kitchen Gourmet XQ-673H replace the power switch.
  1. Turn the Kitchen Gourmet upside down.
    • Turn the Kitchen Gourmet upside down.
    • Make sure the device is unplugged before continuing.
  2. Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device. Remove the bottom cover. Remove the bottom cover.
    • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed. Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed.
    • Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed.
  4. Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch. Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch. Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch.
    • Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch.
Abschluss
Sean Perry
425 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015
USFSM-STEWART-W15S1G3
4 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 204
