Zum Hauptinhalt wechseln
Xbox 360 Controller Shell & Thumbstick Replacement
Was du brauchst
  1. Xbox 360 Controller Shell & Thumbstick Replacement, Ensuring Safety: Schritt 1, Bild 1 von 1
    • Remove all batteries or power sources from remote.
    • This is to ensure that there are no electric currents traveling through the remote, ensuring you will not be shocked.
    • This is very important.
  2. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 2, Bild 1 von 1
    • Using a TP Torx T8 Screwdriver, remove all 6 screws from the back of your controller.
    • Keep the screws in a safe place to ensure you will not lose them.
  3. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 3, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 3, Bild 2 von 2
    • Remove barcode sticker from back wall of battery port.
    • Remove hidden screw from location of sticker with the same TP Torx T8 Screwdriver.
  4. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 4, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 4, Bild 2 von 2
    • Pry open the controller. Optionally, gently push in the thumbstick to eject the back half. (Some buttons may fall out.)
    • This will leave you with 2 separate pieces. Disconnect rumble motors, using fingers on sides of connectors.
  5. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 5, Bild 1 von 1
    • To remove bumper housing and bottom piece, pull away from the shell (along the axis of the screwposts).
  6. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 6, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 6, Bild 2 von 2
    • Remove all mesh and buttons from controller, as well as the motherboard.
    • Remember to keep small parts in a safe place to prevent the loss of a part.
    • Later photo will clarify which button goes in which hole.
  7. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 7, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing the Shell: Schritt 7, Bild 2 von 2
    • To remove arrow keys, locate the screws hidden within the key.
    • Using 1.5 crosshead screwdriver, remove these screws and "store them in a safe place."
  8. Xbox 360 Controller Shell & Thumbstick Replacement, Cleaning the Controller: Schritt 8, Bild 1 von 1
    • Clean shells and buttons with rubbing alcohol if needed.
    • Do not consume rubbing alcohol.
  9. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 9, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 9, Bild 2 von 2
    • Insert buttons into new shell as pictured.
    • Place mesh back onto buttons.
  10. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 10, Bild 1 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 10, Bild 2 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 10, Bild 3 von 3
    • Snap arrow keys into hole.
    • Replace the screws and place mesh over keys.
  11. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 11, Bild 1 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 11, Bild 2 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 11, Bild 3 von 3
    • Place the triggers and the motherboard in their respective places.
    • Re-attach rumble motors. Note orientation of T-slot in connector.
  12. Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 12, Bild 1 von 2 Xbox 360 Controller Shell & Thumbstick Replacement, Reassembly: Schritt 12, Bild 2 von 2
    • Close controller and replace the screws with the TP Torx T8 Screwdriver.
  13. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 13, Bild 1 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 13, Bild 2 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 13, Bild 3 von 3
    • Complete steps 1-4 on the controller with the faulty thumbstick.
  14. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 14, Bild 1 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 14, Bild 2 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 14, Bild 3 von 3
    • To remove thumbstick, pull the thumbstick vertically off of its base.
    • Place the new thumbstick onto its base, pushing it down as far as possible without breaking the base.
    • If you have purchased the wrong style of thumbstick, superglue, hot glue, or any other adhesive should work fine. Simply use a needle to put some adhesive and/or glue into the hole.
  15. Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 15, Bild 1 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 15, Bild 2 von 3 Xbox 360 Controller Shell & Thumbstick Replacement, Replacing Thumbstick: Schritt 15, Bild 3 von 3
    • Once your thumbstick is in place, complete steps 9-12 to reassemble.
Abschluss
You have successfully replaced the shell, and thumbstick, on your Xbox 360 Controller, congratulations!
12 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Ok, so I did this exactly as shown but now my controller doesn't work. I'm an fps player and I need to aim down sights but the left trigger doesn't work. But when I open up my menu (Xbox guide) it won't stop aiming down sights even though I'm not touching the trigger at all. It works perfectly fine on everything else like the guide or Netflix but doesn't work for things like destiny or battlefield 4. And yes it worked before and everything else works. If you can help please do. Cause I spent around $40 on everything
Ethan Schaffer - Antwort
"Security" Torx T8 is necessary, since the screw heads have center pins.
Michael Folsom - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 71
Insgesamt: 11,612
