Zum Hauptinhalt wechseln
Xbox Duke Controller Face Buttons Replacement
Was du brauchst
  1. Xbox Duke Controller Face Buttons Replacement, Face Plate: Schritt 1, Bild 1 von 3 Xbox Duke Controller Face Buttons Replacement, Face Plate: Schritt 1, Bild 2 von 3 Xbox Duke Controller Face Buttons Replacement, Face Plate: Schritt 1, Bild 3 von 3
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
  2. Xbox Duke Controller Face Buttons Replacement: Schritt 2, Bild 1 von 3 Xbox Duke Controller Face Buttons Replacement: Schritt 2, Bild 2 von 3 Xbox Duke Controller Face Buttons Replacement: Schritt 2, Bild 3 von 3
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
  3. Xbox Duke Controller Face Buttons Replacement, Face Buttons: Schritt 3, Bild 1 von 3 Xbox Duke Controller Face Buttons Replacement, Face Buttons: Schritt 3, Bild 2 von 3 Xbox Duke Controller Face Buttons Replacement, Face Buttons: Schritt 3, Bild 3 von 3
    • Remove the silicone pads and pull out the directional pad assembly.
  4. Xbox Duke Controller Face Buttons Replacement: Schritt 4, Bild 1 von 3 Xbox Duke Controller Face Buttons Replacement: Schritt 4, Bild 2 von 3 Xbox Duke Controller Face Buttons Replacement: Schritt 4, Bild 3 von 3
    • Using a plastic opening tool, remove the plastic plate from the bottom of the directional pad assembly.
    • Pull out the silicone pad.
  5. Xbox Duke Controller Face Buttons Replacement: Schritt 5, Bild 1 von 2 Xbox Duke Controller Face Buttons Replacement: Schritt 5, Bild 2 von 2
    • Remove the silicone pads from the top plate of the controller and remove all of the face buttons.
    • To replace the buttons, line them up with the grooves in the top plate.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025 Mitglied von UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025
UMASSD-GULBRANDSEN-S25S1G1
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 317
