Was du brauchst
You can pop the connector up to remove the ribbon easily
Ribbon Cable
Desolder the 4 wires on each side, these control the vibrations and the RT LT
Pull up from the "top" side of the controller on the sister board.
Pry the middle section up from the home button side.
Now you can remove the buttons themselves.
40 weitere Nutzer:innen haben diese Anleitung absolviert.
14 Kommentare
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Thanks for the info
