Zum Hauptinhalt wechseln
Was du brauchst
  1. Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: Schritt 1, Bild 1 von 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: Schritt 1, Bild 2 von 3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: Schritt 1, Bild 3 von 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Plastic Enclosure Replacement: Schritt 2, Bild 1 von 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Plastic Enclosure Replacement: Schritt 3, Bild 1 von 2 Xbox One S All Digital Edition Plastic Enclosure Replacement: Schritt 3, Bild 2 von 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Plastic Enclosure Replacement: Schritt 4, Bild 1 von 1
    • Flip the metal enclosure so that the fan cover is on top.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jules Hajjar
1.372 Reputation
8 Anleitungen geschrieben
Cal Poly, Team S12-G6, Regan Fall 2019 Mitglied von Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 8
Letzten 30 Tage: 64
Insgesamt: 1,633
