Einleitung
This is the wireless connection for the Xbox controllers and Headsets with the Xbox Series One S. You'll notice it has a Wifi mac address. Headsets and controllers disconnecting is a symptom of this card having issues. It's possible removing the card, cleaning the contacts, and reseating will return the card to normal behavior before ordering a replacement.
If your Xbox One S is not picking up motion signals when playing certain games follow this guide to replace your IR blaster. Make sure to check that you are within line of sight of the front of the Xbox One S and there is no barrier between the user and the device.
Was du brauchst
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
Gently separate the interior case from the white exterior case using the appropriate method.
Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
Use a Torx T8 screwdriver to remove the four 15 mm screws with orange circles around them.
Gently pull the IR blaster off the case.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
When the board gets replaced does the power light still function normally? I just replaced one because a power button failed and while the new switches work the indicator lights will not power on
Question. What's size and type of button does this board use? I have one with the eject and sync button sheered off.
