Einleitung
The circuit board in the headset adapter relays information between the buttons on the adapter, the controller, and the headset. If the headset or adapter have lost their functions, then you may need to replace the circuit board. The circuit board consists of two parts connected to each other by a group of wires.
Was du brauchst
Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
Do the same to the other side until the casing comes off.
Remove three 5.0 mm T5 Security Torx screws along the edges of the controller housing.
Remove two 8.0 mm T5 Security Torx screws near the top-center of the adapter.
Pull back on the controller USB connector with your interview to separate the main adapter circuit board from the rubber mold in the button panel.
Remove the two 5.5 mm Phillips #00 screws connecting the smaller circuit board to the adapter housing. The smaller circuit board should come right off.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where do i get the circuit board to buy ?
Thank you, I opened the adapter in minutes, which is all I wanted to do.
