Was du brauchst
Gently pull up on the speaker cable connector to disconnect it from the front panel board.
Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
Lift the Wi-Fi board straight up from its socket in the upper metal case.
Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
