Zum Hauptinhalt wechseln
Xbox One Wireless Controller (1697 Model) D-pad Replacement
Was du brauchst
  1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: Schritt 1, Bild 1 von 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: Schritt 1, Bild 2 von 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: Schritt 1, Bild 3 von 3
    • Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
    • Be careful not to break the clips when removing the handles.
  2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover and the batteries by sliding the cover up.
  3. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 3, Bild 1 von 1
    • Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
    • The screw underneath the battery pack is located under the sticker.
  4. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 4, Bild 1 von 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 4, Bild 2 von 3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 4, Bild 3 von 3
    • Remove the front cover of the controller. using the spudger.
  5. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 5, Bild 1 von 1
    • Remove the back cover of the controller using the spudger.
  6. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 6, Bild 1 von 2 Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 6, Bild 2 von 2
    • Remove the metal ring surrounding the D-pad.
  7. Xbox One Wireless Controller (1697 Model) D-pad Replacement: Schritt 7, Bild 1 von 1
    • Remove the D-pad from the device.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 60
Letzten 30 Tage: 271
Insgesamt: 7,173
