Einleitung
If your Xbox One Wireless Controller (model 1697) Directional-pad (D-pad) is not working when your thumb presses the button, then use this guide to replace the D-pad. The D-pad is the raised, “plus-sign” looking button that is located between the left and right thumb sticks that helps the user adjust the focus or other controls of a specific Xbox One game. Before removing the D-pad, make sure to power off your Xbox One controller completely.
Was du brauchst
Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
