Was du brauchst
Remove the side handles by wedging a spudger in between the front and side panels.
To pry the side panel off move the spudger back and forth do this along the entire seam to remove the side panel.
Using a T8 security torxs screwdriver remove the five 10mm screws from the back of the controller.
One of the screws is hidden behind the label you can either remove the label or poke a hole through it.
2 weitere Personen haben diese Anleitung absolviert.
